Results 1 to 2 of 2
Thread: Ford Focus Brake Warning On Dash
  1. #1
    Just wondering if there is a brake light warning on the dash when it is time for the pads etc to be changed.
    Thanks,
    Joe
  2. #2
    Ah Jayses Joe, surely you can figure that out on your own!
    Here is a place to start: https://www.google.ie/search?sxsrf=A...39._hfJbsUJUw0
    ...or you could have a look at the brakes to see if there is a wire attached to the pads (not to be confused with the wire from the ABS).
    ...or you could swallow your pride and do what nobody does, consult the least-read publication in the world, The Driver's Handbook.
    ________
    Wheelnut
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
