Page 1 of 58 1231151 ... LastLast
Results 1 to 10 of 579
Thread: e30mclow's latest e30
    e30mclow's latest e30 -> Now going 1jz + 6 Speed
    Carrying on from some posts in my S4 thread..
    Picked up an e30 325i last night. It is rougher than a sailor's sac, but is a cheap means of having some fun.
    $1,500.
    Spec:
    • Rusty Scuttle
    • Rear Pocket (under the battery) has a fine big hole in it
    • Paint is bad
    • Sunroof tray is rusty
    • Interior needs to be disinfected
    • Every bushing is gone
    • Misfiring under load
    • Exhaust is swiss cheese
    • Sills and jacking points are solid
    • Arches are solid
    • Front panel is pretty straight
    • There is an oil leak of some sort
    • The sunroof visor covers previous hole repairs
    I'm just interested in having something that I don't necessarily need to care too much about, and won't bust the bank if it breaks.
    The thought of a solidly setup e30 with an LSD on a greasy road it what it is all about.
    I had to sit on my hands last night to avoid going to town with the credit card before getting a clear picture of how bad the car might actually be.
    Plans:
    Next 1-2 months (in order of priority)
    • Clinical Clean of the interior (seats out, steam clean, dead frog removal etc)
    • Full Engine Service (belts, fluids, plugs and ignition system)
    • New Exhaust
    • Full Polybush Bushing Kit
    • New Brakes & SS Hoses
    • Z3 1.9 Shifter and New Shifter Cup/Bushing
    • New iS Front Lip (or an MTech II Valance if I can find one)
    • Find an LSD somewhere
    • BC Racing Coilovers
    Long Term
    • Get my hoard from home shipped over
    • Safety Devices Half Cage
    • Schmidt Modernline 16x9J Wheels
    • e46 steering rack
    • Start making a go at painting it
    Done Deal Photo- MINT!!!
    Actual photos (not so mint)
    One of many dead frogs
    Disgusting interior
    Engine
    **CURRENT SPEC** Updated June 2020
    Legally on the road as of June 11th, 2020.
    ENGINE
    Toyota 1JZ-GTE non-VVTi: Cold Compression Test Readings (155,160,155,160,160,160)
    Custom Aluminum Engine Mounts with Hockey Puck bushings
    Driftmotion Single Turbo Manifold
    Driftmotion 40-1 T4 Single Turbo (Garret GT35 Core) with Polished Compressor and Ceramic Coated Hot Side
    Turbo Blanket
    3" V-Band Downpipe (bunged for ECU o2 and Aem AFR o2)
    -10 AN Oil Return
    Braided High Pressure Oil Feed Line
    3" Custom Stainless Steel Exhaust to APR resonator and back box
    3" Inlet/Outlet Large Front Mount Intercooler (maximum size that could be "hidden")
    2.75" Intercooler Piping
    Genuine Tial BOV
    Genuine HKS External Wastegate with homemade screamer pipe
    Painted Cam Covers and Hydro-Blasted Intake Manifold & TB
    Shortened Throttle Body (to allow for IC piping + rad)
    Custom 2 Core Aluminum Rad - tucked into the front core support
    14" Spal Slim Electric Puller Fan + Shroud (made from baking tray)
    Wiring Specialities Plug & Play Harness
    Patch/Jumper Harness
    6 Point Grounding Harness
    Apexi Neo AFC (fuel controller)
    HKS FCD
    AEM Tru Boost Controller/Gauge
    AEM AFR Gauge
    Ford Mustang 5.0 3 wire o2 Sensor
    Mustang 5.0 o2 Sensor plug spliced into JZ Harness
    Aeromotive Stealth In Tank Fuel Pump
    440cc Injectors (JDM 2JZ)
    Aeroquip Fuel Pressure Regulator modified to fit end of OEM 1JZ fuel rail
    Chase Bays JZ-BMW rack High Pressure Line
    New OEM BMW Rack-Reservoir line
    Oil Level Sender Delete Plate
    1JZ Water Neck Drilled & Tapped for e30 Water Temp Sender
    Water neck also tapped for air bleeder screw, to avoid common air pocket/cavitation
    New Behr Coolant Reservoir
    DRIVETRAIN
    Low Mileage Nissan CD009 6 Speed Transmisison
    1JZ Adapter Plate + Custom Flywheel (Collins Engineering)
    ACT Stage 4 Clutch & Pressure Plate (650ft/lb)
    Braided Clutch Line
    Custom CNC'd Shifter Adapter to relocate Nissan Shifter to e30 position (via CD009 transmission service opening).
    Homemade Transmisison Mount/Brace utilizing the e30 Bolting Points
    Trans Tunnnel had to be removed and a new larger tunnel welded in.
    Nissan Titan Slip Yoke
    Homemade conversion to a Wilwood small diameter clutch master cyliner.
    Custom Front Half Shaft (a single piece won't clear the petrol tank)
    CHASSIS
    BC Racing Coilovers with front Camber Plates
    Garagistic Front & Rear Sway Bars
    Garagistic Front & Rear Adjustable Sway Bar Links
    Garagistic Front & Rear Strut Braces
    Front & Rear Subframe Reinforcements
    Front Subframe modified for External Wastegate clearance
    Powerflex Purple Subframe, Trailing Arm and Differential bushings
    Adjustable Camber/Toe Eccentric Rear Subframe
    3.73LSD + 2.91LSD (final to be decided)
    Treehouse Racing Increased Caster Front Control Arm Bushings ("Lollipops")
    New Front Control Arms
    Braided Brake Lines X 6
    New Wheel Bearings x 4
    Garagistic Solid Steering Column Bushing/Guibo
    e46 "Purple Tag" Steering Rack
    New Behr e46 Steering Rack Bellows
    SRS Concept Inner Tie Rod Spacers (increased lock)
    MRT Roll-Center Correction Kit (not fitted yet, waiting on spare arms)
    Oversized PS Pump Pulley
    Modified Brake Pedal Ratio for improved feel/feedback
    Brake Booster Deleted (no room with the stock JZ inlet manifold) - Massive Motorsport
    VW 19mm F/R Master Cylinder - best compromise for pedal actuation and feel
    Homemade Hardlines from ABS Pump
    E30 front Spindles converted to 5x120, thus retaining the e30 camber/caster settings
    Z4 Rear Hubs pressed into e30 rear trailing arms - 5x120
    e46 325i Front & Rear Calipers (with new pistons, seals, bleeders and guides)
    e46 325i Vented Front & Vented Rear Rotors (300mm & 279mm drilled & grooved)
    New Brake Pads
    Stop-Tech e46 Front Braided SS Brake Lines
    INTERIOR
    JDM Integra Type-R Recaro SR3 Reclinging Seats (Similar to SportEvo Seats)
    Massive Brakes Seat Mounts
    Cardinal Red Door Cards, Carpet, Rear Bench
    Sparco Steering Wheel
    Momo Steering Wheel Hub
    Homemade super tall shifter
    3D Printed Center Vent Gauges
    Tach/Coolant Temp/Oil Light working with the Toyota ECU
    Delrin Solid Throttle Pedal Bushing (0 Play/Slop)
    Crack Free Dash (awaiting installation)
    EXTERIOR (Still looks horrible!)
    Painted in my garage using Rustoleum rattle cans.
    New iS Lip
    New Oem Lip Clips
    "Euro" Grills
    Genuine Euro "Smiley" Lights
    Genuine Tech 1 Rear Spoiler
    Euro" Rear Plate Surround
    Homemade quick release bonnet latch
    Rear Arches rolled, but not pulled
    "Pop Out" rear windows (Awaiting installation)
    Genuine Alpina 162 Front Valance (Option 1)
    Genuine Mtech 2 Front Valance & Clips (Option 2)
    Rare NOS Heckblende
    WHEELS
    5x120*
    Pontiac GTA 16x8 et0 & et16 with modified hubs (increased bore)
    4 x 205/45r16 Firestone Indy 500s
    BBS RS720 17x8 et20 (slowly being refurbed)
    Current Bad Ideas:
    Daily - 1998 Pajero Evolution
    Project - 1990 BMW e30 1JZ
    Previous "Better" Ideas: 2 x Stage III Audi B5 S4, e30 m3, e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 e21 316
    There's hope for it yet!
    At least she doesn't have those awful US spec bumpers. Single exhaust exit is unusual in a sixer. Is that an airbag steering wheel? Standard ride height on an e30 is just comical isn't it!!
    The other tail pipe is in the boot. It had rusted off!
    That's the main reason I went for it, it not having the ugly US bumpers. Yes, they had airbags over here.
    Shopping list:
    Immediate Items
    Full Service Kit $460.00
    Misc Cleaning Items $75.00
    Exhaust $350.00
    Bushings (Powerflex) $345.00
    Clutch Items $50.00
    Brakes (pads, fluid and ss lines) $180.00
    BC Coils $980.00
    Underside Paint Mat. (seems as I'll have the subframe out) $180.00
    Shifter Lever & Bushings (have always loved the Z3 1.9 shifter) $160.00
    Immediate Total $2,780.00
    A sturdy front strut brace is a worthy addition too, especially with stiffened sussy
    Quote Originally Posted by Auto_Motive View Post
    Very True. Garagistic do a ton of e30 specific bits & pieces, including a front & rear brace combo:
    https://store.garagistic.com/bmw-per...trut-bar-combo
    Current Bad Ideas:
    This post comes from live beneath the car, where I'm happy to confirm that it already has an LSD!
    So f-Ing happy! That's $400 saved for other things
    Current Bad Ideas:
    Excellent!!! I found out my car has an lsd on Saturday but the attached is the state of the planet and sun gears. It was bittersweet.
    I can't wait to see how this project unfolds, the s4 has been a great read but you have a lot to live up to after that
    Any plans for an engine swap?
    Bittersweet indeed!
    I wouldn't mind putting an s54 in there, but don't think I'll be in the US long enough to pull it off.
    Ripped into it tonight and started ordering parts.
    Surprisingly clean where e30s are usually rust. The only really bad spots are the roof, and this rear pocket;
    The other side is perfect
    Clean battery tray & chassis legs
    Interior removed for a serious clean
    ..during which I found a whole pile of service history back to the 90s.
    Ordered a complete service kit, powerflex bushing kit and z3 short shifter & busing kit tonight.
    The plugs are rotten and she could do with a good "tune up" as the yanks say.
    From there I'll see if it is worth the $ for coilovers etc
    Current Bad Ideas:
    The plot thickens..
    Looking at my last photo, it would suggest that the gears that turn the odometer have been worn out for at least the last 9 years lol.
    Same mileage in 2008 as it had in 2013, as it has today.
    Better do the timing belt!
    Current Bad Ideas:
    I thought when you said clean out dead frogs that you were using a metaphor!
